Indice
Indice
Find back
Suunto Ambit3 Run automatically saves the starting point of your exercise, if you are using GPS. With Find back, Suunto Ambit3 Run can guide you directly back to your starting point (or to the location where the GPS fix was established).
To find back:
- While you are in a sport mode, keep Next pressed to access the options menu.
- Press Next to select navigation.
- Scroll to Find back with Start Stop and select with Next. The navigation guidance is shown as the last display on the selected sport mode.
