Buy Suunto Ocean or EON Core - Save 50% on Tank Pod. Shop now!
Can I use any kind of USB charger when charging Suunto EON Core / Suunto EON Steel?
The USB charger needs to be able to supply 5V and min 500mA to charge the device.
CAUTION: You may only charge you device using USB adapters that comply with the IEC 60950-1 standard for limited power supply. Using non-compliant adapters may damage your device.
