Summer Sale: Up to 20% off on selected products! Discover
Strap Deals: 50% off on selected products! Discover
What can I do if the altitude readings during daily use in the Alti-Baro display of my Suunto Ambit3 Peak are incorrect?
If your watch shows incorrect altitude or barometric readings in the Alti-Baro display of your watch, the following tips may resolve the issue.
Check which Alti-Baro profile is set in the watch. To improve the accuracy of altitude readings during daily use, we recommend using the Automatic (Auto) profile. You can change the settings on your watch.
To set the Alti-Baro profile in your watch:
1. Keep NEXT pressed to enter the options menu.
2. Scroll to ALTI-BARO with LIGHT and enter with NEXT.
3. Enter PROFILE with NEXT.
4. Scroll to the desired setting with LIGHT and confirm with NEXT.
Make sure FusedAlti is enabled. GPS and barometric altitude are combined to provide a more reliable altitude reading with this feature enabled. Read more in the user guide. When enabled, FusedAlti is activated every time you start an exercise that uses GPS.
To activate FusedAlti:
3. Scroll to FusedAlti with START and press NEXT to enter the menu.
4. Select ON with LIGHT and confirm with NEXT.
Note: It takes several minutes for FusedAlti to activate in good conditions. During that time, your watch shows your approximate barometric altitude. Your altitude reading and altitude history in the exercise will be corrected once your real altitude is defined via FusedAlti.
Set a new altitude reference value. Learn how to set this value for your watch in the FAQ “How to set a new altitude reference value for Ambit3 Peak”.
FIND MORE SUPPORT FOR:
