Sign up for the newsletter and get 10% off | Easy returns
Measurements | 50 x 50 x 15,5 mm / 1,97 x 1,97 x 0,61 " |
Weight | 72 g / 2,54 oz |
Bezel material: | Polyamide |
Glass material: | Mineral crystal |
Case material: | Polyamide |
Strap material: | Silicone |
What's in the box? | Suunto Ambit3 Run Lime, Suunto Smart Sensor Lime, USB cable, Quick Guide, Warranty Leaflet |
Country of manufacture | FI |
RUNNING AND TRAINING
CONNECTIVITY
ENRICH, RELIVE AND SHARE
*with the Suunto app
**with Suunto Smart Sensor
Note! The Ambit3 watches are not compatible with ANT+™ (e.g. Suunto ANT PODs, Suunto Dual or Suunto ANT belt)
Water resistance | 50 m |
Battery type | rechargeable lithium-ion |
Time, date | |
Alarm clock | 1 daily alarm |
Dual time | |
Automatic timekeeping | |
Countdown timer | |
Stopwatch timer | |
Languages | EN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH |
Backlight | LED |
Configurable backlight | brightness / mode |
Button lock | customizable |
Invert display | |
Display type | matrix |
Display resolution | 128 x 128 |
Battery indicator | percentage / icon |
Metric and imperial units | |
Autoscrolling of exercise displays | |
Memory left indicator | |
Firmware upgradable |
In time mode | 14 days |
Training mode with GPS | 10, 15, 100 h |
Watch customization | USB cable |
Connectivity (between devices) | Bluetooth Smart |
Data transfer | Wireless / USB cable |
Phone notifications on the watch | with Suunto App |
Compatible with online sports communities | Strava, TrainingPeaks, MapMyFitness and others (available in Suunto app) |
Smartphone compatibility | iPhone, Android |
Compatible with Suunto Apps | |
Max. nr. of apps per sport mode | 5 |
Logging of app specific metrics | |
Most recommended apps by activity | |
Chrono, GPS, HR, weather and altitude data | yes, excluding weather |
Running, cycling, swimming data | yes, excluding cycling power/swimming |
Rich math functions, if/then-logic, sound, backlight, etc. | |
Create own metrics with advanced formulas |
Digital compass | |
Tilt compensation | full |
Direction scale | degrees / mils |
Needle | north indicator |
Bearing lock with orienting indicator | |
Compass accuracy | 5° |
Compass resolution | 1° |
Declination correction | |
Bearing lock with direction indicator |
Operating temperature | -20° C to +60° C / -5° F to +140° F |
Storage temperature | -30° C to +60° C / -22° F to +140° F |
Recommended charging temperature | 0° C to +35° C / +32° F to +95° F |
Satellite systems | GPS |
GPS recording rate | 1, 5, 60 s |
Coordinate systems | WGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000) |
Waypoint and visual route navigation | |
Max. nr. of Points of Interest (POIs) | 250 |
Route planning | in Suunto Movescount.com |
Route points per route / POIs in watch | 1000 / 250 |
Track logging, viewing and sharing | |
GPS track analysis | |
Find back | |
Track back | yes |
Altitude graph | |
Vertical speed | GPS based |
Total ascent/descent | GPS based |
Altitude difference | yes** |
Log recording rate | 1, 10 s |
Resolution | 1 m |
Range | -500 - 9999 m |
GPS altitude |
Distance based autolaps | |
Chrono | |
Laps | > 1000 |
Autopause | |
GPS speed and distance | Integrated |
Foot POD support | Bluetooth Smart |
RR interval | |
Heart rate in beats per minute | |
Heart rate in % of max hr | |
Records heart rate in swimming | yes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor |
Real-time average and max heart rate | |
Heart rate limits | |
Heart rate graph in real time | |
Calories | |
Peak Training Effect | |
Recovery time | |
Real time EPOC | yes** |
Speed and heart rate-based guidance during exercise |
Training based recovery time | |
Sleep recovery test (Firstbeat™) | |
Quick recovery test (Firstbeat™) |
Log summary on the watch with lap details | |
Training analysis | in Suunto App |
Training logbook with story and image support | in Suunto App |
Customizable sport modes and displays | 10 modes / 8 displays per mode |
Running pace | |
Suunto FusedSpeed™ | |
Average pace in real time | |
Running cadence | watch or Foot POD |
Foot POD calibration | manual or GPS |
Average stride length | yes** |
Lap comparisons by kilometer/mile | |
Marathon End-time Estimator | yes** |
Running Performance (Firstbeat™) |
Cycling speed | based on GPS |
Average speed in real time | based on GPS |
Openwater swim pace and distance | |
Records heart rate in swimming | Yes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor |
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto watch.
Your country or region:
United States
