Buy Suunto Ocean or EON Core - Save 50% on Tank Pod. Shop now!
Sign up for the newsletter and get 10% off | Free returns
Measurements | 73 x 165 x 35 mm / 2,87 x 6,5 x 1,38 " |
Weight | 210 g / 7,41 oz |
Bezel material: | Composite |
Glass material: | Acrylic |
Case material: | Composite |
Strap material: | Elastomer |
Country of manufacture | FI |
Declination correction | yes |
Water resistance | 100 m (ISO 13319) |
Battery life 100 dives/year | 1.5 years |
Battery type | |
User replaceable battery | |
Time, date | |
Alarm clock | 1 daily alarm |
Languages | EN |
Backlight | electro-luminescent |
Configurable backlight | duration: 5, 10, 20, 30, 60 s |
Display type | matrix |
Display resolution | 49 x 22 |
Battery indicator | low battery indicator |
Metric and imperial units |
In time mode | 3 years |
Data transfer | USB cable (optional) |
Compatible with DM5 |
Digital compass | |
Tilt compensation | up to 45° |
Direction scale | degrees |
Needle | compass rose |
Globally balanced | |
Bearing lock with orienting indicator | |
Compass accuracy | 10° |
Compass resolution | 1° |
Operating temperature | 0° C to +40° C / +32° F to +104° F |
Storage temperature | -20 ° C to +50 ° C / -4° F to +122° F |
Maximum operating depth (EN 13319) | 100 m / 328 ft (EN 13319, ISO 6425) |
Nitrox (and air) | |
Gauge | |
Dive time | 0 to 999 min |
Surface time | 0 to 99 h 59 min |
No fly time | |
Safety Stop | |
Deep Stop | |
Ascent time display | 0 - 99 min (- - after 99) |
CNS/OTU (OLF) calculation | |
Hose air integration | |
Decompression model | Suunto RGBM |
Personal adjustment | 0 - 2 |
Altitude adjustment | 0 - 300 m / 300 -1500 m / 1500 - 3000 m |
Gases | up to 2 gases (Oxygen 21 - 99%) |
Gas max pO2 | 1.2 - 1.6 |
Gas switching | |
No-decompression planner | |
Logbook memory | ~42 h (20 s sampling rate) |
Logbook bookmarks | |
Logbook sampling rates | 1, 10, 20, 30, 60 s |
Dive history | lifetime |
Dive time | |
Maximum depth | |
Tank pressure | |
High pO2 (hyperoxic) | |
Too fast ascent | |
Decompression ceiling violation | |
CNS/OTU (OLF) 80% / 100% | |
Switch gas (better gas is available) |
Temperature display range | -20° C to +50° C (+/- 2° C) / -9° C to +122° F (+/- 3.6° F) |
Temperature resolution | 1° C / 1.5° F |
Temperature |
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto dive computer.
