Sign up for the newsletter and get 10% off | Easy returns
The Suunto DM5 allows you to download your dive logs for advanced analysis and create dive plans. Transfer dive logs from your compatible Suunto dive computer, upload dive plans, and customize your dive computer.
At the heart of every Suunto dive computer is an algorithm – the reduced gradient bubble model (RGBM) – that calculates decompression for a dive. Relentlessly pursuing ever best models for divers of all types, Suunto continues to push for RGBM perfection. Suunto has been developing RGBM algorithms together with Dr. Bruce Wienke for well over a decade.
Rooted in Finnish design, Suunto puts a premium on simplicity and functionality. Noted for their aesthetic appeal, comfort, and practicality, Suunto products have won numerous awards over the years.
Measurements | 65.9 x 60.4 x 28.7 mm / 2.59 x 2.38 x 1.13 " |
Weight | 68 g / 2.4 oz |
Bezel material: | Composite |
Glass material: | Acrylic |
Case material: | Composite |
Strap material: | Elastomer |
What's in the box? | Suunto Vyper Air, USB cable, dive manuals on DVD, Vyper Air Quick Guide and dive legal leaflet with warranty information |
Country of manufacture | FI |
Declination correction | yes |
Water resistance | 100 m (ISO 6425, EN 13319) |
Battery life 100 dives/year | 2 years |
Battery type | |
User replaceable battery | |
Time, date | |
Alarm clock | 1 daily alarm |
Languages | EN |
Backlight | electro-luminescent |
Configurable backlight | duration: 5, 10, 20, 30, 60 s |
Display type | matrix |
Display resolution | 49 x 22 |
Battery indicator | low battery indicator |
Metric and imperial units |
In time mode | 3 years |
Data transfer | USB cable |
Connectivity (between devices) | inductive |
Compatible with DM5 |
Digital compass | |
Tilt compensation | up to 45° |
Direction scale | degrees |
Needle | compass rose |
Globally balanced | |
Bearing lock with orienting indicator | |
Compass accuracy | 10° |
Compass resolution | 1° |
Operating temperature | 0° C to +40° C / +32° F to +104° F |
Storage temperature | -20 ° C to +50 ° C / -4° F to +122° F |
Maximum operating depth (EN 13319) | 100 m / 328 ft (EN 13319, ISO 6425) |
Nitrox (and air) | |
Gauge | |
Dive time | 0 to 999 min |
Surface time | 0 to 99 h 59 min |
No fly time | |
Safety Stop | |
Deep Stop | |
Ascent time display | 0 - 99 min (- - after 99) |
CNS/OTU (OLF) calculation | |
Wireless air integration | optional |
Decompression model | Suunto RGBM |
Personal adjustment | 0 - 2 |
Altitude adjustment | 0 - 300 m / 300 -1500 m / 1500 - 3000 m |
Gases | up to 2 gases (Oxygen 21 - 99%) |
Gas max pO2 | 1.2 - 1.6 |
Gas switching | |
No-decompression planner | |
Logbook memory | ~42 h (20 s sampling rate) |
Logbook bookmarks | |
Logbook sampling rates | 1, 10, 20, 30, 60 s |
Dive history | lifetime |
Dive time | |
Maximum depth | |
Tank pressure | |
High pO2 (hyperoxic) | |
Too fast ascent | |
Decompression ceiling violation | |
CNS/OTU (OLF) 80% / 100% | |
Switch gas (better gas is available) |
Temperature display range | -20° C to +50° C (+/- 2° C) / -9° C to +122° F (+/- 3.6° F) |
Temperature resolution | 1° C / 1.5° F |
Temperature |
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto dive computer.
