Tones and vibration alerts are used for notifications, alarms and other key events and actions. Both can be adjusted from the settings under General » Tones.
Under General » Tones » General, you can select from the following options:
Under General » Tones » Alarms you can switch vibrations on and off.
You can select from the following options:
Your country or region:
United States
