Software updates – Suunto Vertical
Enjoy the convenience of over the air software updates via Suunto app so that your Suunto Vertical always has the latest and greatest software.
Over the air software update
When an update is available and your watch is connected with Suunto app, the software update will be downloaded to the watch automatically.
Once the software is downloaded to your watch, the watch will update itself during the night as long as the battery level is at least 50%.
If you want to install the update manually before it happens automatically during the night, navigate to Settings > General and select Software update.
Release notes
2.37.48
Staged update starting on October 2nd 2024
This update brings following bug fixes:
  • Fixed cases where sleep tracking and OHR stopped working
  • Fixed a case where pool swim distance was wrong in logbook
  • Fixed a case where power consumption remained high after navigation
2.37.34
Staged update starting on September 4th 2024
This update brings new features, improvements and bug fixes.
New features:
  • Watchfaces are now transferred to SuuntoPlus store
  • After the update the watch has only one watch face and new watchfaces can be added to your watch from the SuuntoPlus store in Suunto app
Improvements and bug fixes:
  • Exercise start panel streamlined and made faster
  • Improved capability to determine VO2Max
  • Improvements to Climb Guidance functionality
  • Several cosmetic improvements to menus and watch faces
  • Some language translation corrections
2.35.34
Staged update starting on July 3rd 2024
New features:
  • Climb guidance feature during navigation for routes with elevation data
  • Possibility to select watch face complications
  • Three new watch faces
  • Cumulative data fields as watch face complications
  • Second configurable short cut
  • Screen lock in watch mode
  • Map zooming now possible up to 20km
  • Data field on navigation screen
  • Automatic and customizable map re-center
  • Sport mode specific display settings
  • Browse back one screen in sport mode using long press middle button
  • New pause and exercise end user interface with possibility to browse screens
  • Vietnamese language support
  • Improvements in the battery life with GPS: Vertical 65h - Vertical Solar 90h - Race 50h
  • Improved Emoji support with more characters
  • Improved step counter to avoid misdetection from general hand movements
  • Faster UI browsing
  • New GNSS and OHR software
2.33.16
Staged update starting on May 21st 2024
  • Fixed bug that caused the mobile sync to fail
  • Fixed a problem with SuuntoPlus structured workout guides
2.33.14
Staged update starting on April 23nd 2024
  • Fixed bug that caused device to go blank in charger
  • Fixed a problem with SuuntoPlus device communication
2.33.12
Staged update starting on March 25th 2024.
New features:
  • Map ruler tool shows distance to nearby location when panning map
  • Improved high contrast map style for use with always on display
  • Log pause resume reminder when starting to move
  • First version of emoji support in mobile notifications
  • Improved training zone data sync perfromance
  • Suunto app sync speed improved
  • Running race estimate problems fixed
2.30.38
Staged update starting on December 18th 2023.
This update brings improvements and bug fixes.
Improvement and bugs fixed:
  • Several improvements to general stability
  • Fixed problem with map not showing properly in all locations
  • Fixed missing weather icon from the widget
  • Fixed lap button functionality in SuuntoPlus guides
  • Fixed log summary rendering problems in some cases
  • Fixed some sleep tracking and step counter problems
2.30.26
Staged update starting on November 16th 2023.
New features:
  • New intuitive UI structure with mini widgets and richer customization
  • New Training Zone widgets for Training (TSS), Progress (CTL) and Recovery (HRV and TSB)
  • HRV recovery measurement during sleep
  • Multiple clock alarms instead of one
  • Find my phone function
  • Stand up reminder
  • New SuuntoPlus sport apps in some default sport modes
  • Running race estimates for 5k, 10k, half marathon and marathon
Improvements:
  • Improved stability
  • New log summary screen layout
  • Improved notification icons
  • Improved media controls
  • Improved GNSS accuracy with updated GNSS firmware
  • Map zoom level up to 2km instead of 500m
2.25.66
Staged release starting from June 28th, 2023.
This update brings an improvement to openwater swim accuracy.
2.25.64
Staged release starting from June 20th, 2023
Improvements:
  • New GPS firmware improving tracking accuracy
  • Flashlight timeout changed from 30sec to 10min
  • Standby light defaults to OFF in order to save battery
  • Backlight behavior in DND mode improved
  • Voice guidance remembered per sport mode
  • Map style remembered
  • Compass calibration problem fixed
  • SuuntoPlus device connection fixed
  • SuuntoPlus sport app and guide can be used simoultaneously
  • Several Map UI improvements
