Summer Sale: Up to 25% off on selected products! Discover
Suunto Ocean User Guide
Switch window for freediving
Similarly to scuba dive, the switch window at the bottom of the dive screen can contain different types of information that can be changed by short pressing the lower button. The following data can be found in the switch window:
Switch windowSwitch window contentExplanation
switchfield temperatureTemperatureThe current temperature in degrees Celsius or Fahrenheit, depending on unit settings.
switchfield max depthMax depthThe maximum depth reached during the current dive.
switchfield timeClockThe time in a 12- or 24-hour format, based on the set time format under Time/date settings in the watch.
switchfield batteryBatteryThe remaining battery level as percentage. See Mandatory dive alarms for battery alarms.
switchfield average depthAverage depthThe average depth of the current dive is calculated from the moment the start depth is exceeded until the dive ends.
switchfield sunset etaSunset ETAThe estimated time until sunset expressed in hours and minutes. Sunset time is determined via GPS, so your watch relies on the GPS data from the last time you used GPS.
switchfield dive countDive countThe number of sets during one freedive exercise.
switchfield total dive timeTotal dive timeThe total time underwater.
switchfield heart rateHeart rateYour wrist-based heart rate.
